CTEK 3300 Battery Charger Installation
#322
#323
I admit that I haven't been through all 17 pages, but the installation couldn't have been easier on my 2013 XKR-S. I needed only a 10mm socket with extension and used existing nuts on the positive battery clamp and the bracket that holds the DVD changer to the trunk floor. I used a multimeter to check that there was zero resistance between the negative battery post and the bracket, so I'm fairly confident that it's an adequate ground. I then used a zip tie around the suspension cross-brace to provide strain relief for the pigtail, and I can have the connecter either above or below the shelf (not shown) that covers the spare tire (if I had one) well. I do also have the CTEK extension cable. The car will unfortunately mostly be parked in my garage for the rest of the winter here. I should be able to find time in to install my Eurotoys upper pulley, though.
Rick'sJag (12-26-2017)
#324
dcmackintosh (12-27-2017)
#325
The following 2 users liked this post by richzak:
dcmackintosh (12-27-2017),
#326
this is a fantastic thread thanks. I bought my CTEC and hooked it up to my totally dead battery just to see the results even though I plan on buying a new battery for my 2012 XKR. WOW the car lights started flashing on and off as did the whole dash board and the driver window went part way down. It looked like a UFO. Anyway I disconnected. Is this because my battery is totally dead? Car won't start by the way.
#327
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
