Ctek / battery question
I have a Ctek 3300 mounted on my 07 XK. The battery charge light never shows it's fully charged. I load tested the battery and it was OK. Battery installed October 2012. I keep the car locked and on Ctek when parked.
Does the fact that Ctek never shows full charge indicate a battery problem despite satisfactory load test?
First question: where is the CTEK unit? if it is IN the car, the simple act of opening the tailgate sets the CTEK into action and that will tell you that the battery is not fully charged, ever. The CTEK unit should be OUTSIDE the car (see photo); that way you can monitor your battery condition.
I use this unit on all my cars. I have my 1966 Mark 2 on the CTEK unit; this car is pre-electronics so the only battery drain is the clock. The CTEK unit shows full charge almost all the time but today I opened the passenger door to put something in; closed it and looked at the CTEK unit. It was charging! these units are so sensitive that even a minuscule drop in voltage (as in putting on the interior lights by opening the door) will send it into action. On the XK, just touching the door handle or the tailgate release will make the CTEK start charging.
So, my question: where is the unit while charging?
SOV211 is correct, by having the CTEK unit inside the trunk, everytime you open the hatch, the CTEK automatically goes from green to amber as the Jag is using power just to open the hatch release.
Quick question - I have CTEK mounted on post in garage with extension cord to AC power. CTEK quick connect extension to cord in XKR. If I disconnect quick connect to go for a drive, is it ok to leave the CTEK unit powered up in standby position? Or do you have to pull the power completely?
Tandemcha (02-24-2015)
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
bobdr1 (02-24-2015)
CTEK smartchargers are "spark proof". There is no way they will create any spark.
For more information on CTEK smartchargers visit their website at:
www.ctek.com
Autospell strikes again. Edit and change "discount" to "disconnect". It's happened to me so I always preview before submitting to be sure there are no misteaks-oops-mistakes.
Stuart
richzak (02-25-2015)
Hello everyone, I just installed my CTEK yesterday…. I have a question. Since the CTEK monitors the battery and offers a slow charge as opposed to a rapid charge, I assume that it is fine to leave the 'trunk mat panel' unit that covers the battery in place while the battery is being charged.
Hello everyone, I just installed my CTEK yesterday…. I have a question. Since the CTEK monitors the battery and offers a slow charge as opposed to a rapid charge only when required, I assume tthat it is fine to leave the 'trunk mat panel' unit that covers the battery in place while the battery is being charged.
Fstbmw1 (03-28-2015)
Guy-Pierre Boucher
09-16-2015 05:55 PM
