CTEK Install Question
Sorry for all of the questions... I'll ease off in a little bit.
I just got my CTEK 3300 and extension cable. I'd like to mount the connector it under the front hood, and keep the connector accessible from the front of the car without popping the hood. Anyone have a setup like this with recommended routing path for the cable?
I looked for under the hood mount points and didn't see anything. The Jump Start terminals are in the trunk and easier than digging out a direct connect to the battery. I am going to put my quick connect trickle charge cable there.
I am out of town so going by memory as I had scoped out my placement already. If you go to the trunk, remove the plastic hatch in front of the drivers side stop lights, at the bottom against the left fender there is a rubber boot cover over the positive terminal. The Jump ground is somewhere in the middle, I didn't look for that as I am planning on using one of the other bolts if it could provide solid ground.
There are lots of threads on this X150 Forum about how to install a CTEK or other battery maintainer, complete with detailed instructions and photos. Learn to use the search function. Many questions have already been addressed and you don't need to reinvent the wheel.
I'll post links after I get home and can use my PC. This reply is from my cellphone.
From my PC:
See these links of most helpful/most viewed:
https://www.jaguarforums.com/forum/x...ook-up-147682/
https://www.jaguarforums.com/forum/x...lation-107738/
https://www.jaguarforums.com/forum/x...lay-ups-73471/
Full list on the X150 Forum (63 threads): https://www.jaguarforums.com/forum/s...archid=4771227
If this was helpful, please press
at the bottom right.
Stuart
From my PC:
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/post_thanks.gif)
Stuart
aholbro1
08-05-2021 05:02 AM
jagent
09-12-2015 01:40 AM
