CTEK Installation
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
So I finally got around to picking up a CTEK MU 4.3 and am preparing to install the pigtail. I've read the other threads for the 3300 and see that the factory recommended installation for the Jaguar-branded charger is with the positive to the battery terminal and negative to a nearby bracket, but my lazy side wants to just hook up to the remote terminals used for jumpstarting. Is there anything really detrimental to hooking up that way? I don't think I saw a definitive answer to this in any of the other threads.
BryanL (07-05-2017)
Simon - You can hook it up to the terminals in the boot and the spare tire compartment. On the other hand if you are making a permanent installation as most of us have done. IMO I would hook it up as described by the CTek people. You can then keep cord out of the boot and let it come out near the lid as described.
Simon Tan (07-05-2017)
Correct. Positive to either the jump start terminal or directory to the positive battery post and the negative to a chassis ground point, not the battery terminal, per jaguar tech doc which I can't find at the moment...
