Dash fan smoking.
Dash fan smoking.
I was sitting at a red light tinkering with the switches, trying to get familiar with the console, the air conditioning was on auto, and I turned the recerculate button on and off. But then I turned the dial all the way up to see how strong the air would blow and it did not seem to blow very hard at all, but the cab started filling with a fine haze, and I noticed smoke coming up from under the hood on the passenger side just in front of the dash area. I dropped the fan back down and everything cleared up, I put the auto back on and everything works normally. Just doesn't like being turned up manually.
Has anyone heard of this, or could I possibly have had a rat chew some wires under the hood.
What did it smell like. Was it wiring insulation smell or rubber or coolant . Is your AC duck bill drain working so you see water dripping under the car. If you turn it back to manual and turn the knob does the fan speed still pick up or do you only have maybe 2 or 3 speeds. Can you repeat the problem . Pop the hood and remove the plastic cover on that side and have someone turn on the fan .
Bobioknight (08-14-2016)
Bought my car a few weeks ago. I noticed smoke coming from under the dash were the fan sits. I had a good idea were it was from because a few days earlier i noticed air con water coming from that area, from what i researched its because of the boocked drainage tube. I unblocked the tube from inside the engine bay and it stopped, then dryed the carpet out.
Stripping out the fan unit i noticed that because there was so much water damage, the fan was stuck. So i replaced both the fan unit and the control module. Now its perfect and i am happy
Thats an option, hope it helps.
As mentioned above pull the plastic cover in the engine compartment near the pass. side and pull out and check the cabin air filter.
Filter was clear. I ran the fan on high and I did not get the smoke, I am kinda thinking maybe it was something else. At the same time I saw the smoke I had plugged my phone / ipad charger into the port in the glove box. I read the manual and it say's don't plug anything into the port until you check with the dealer first. So maybe I overloaded the circuit port. The adapter I use is a dual output type. I had the phone plugged in all day, when I turned up the fan I had also plugged my ipad in to the charger as well, I assumed the fan was the issue but I did unplug the adapter as soon as I realized there was smoke. Any thoughts?
Bobioknight (08-15-2016)
Sorry, no it really did not smell like burning. That's what was so weird, there was none of the usual electronic or wire or rubber burning smell that normally accompanies a hazy "smokey" cab. That's why it took me a few minutes to realize there was something bad happening. This weekend I pulled that filter, it was perfectly clean, blowing it off produced no dust so I expect during the annual service they dropped a new one in. I do have what appears all fan speeds, I tried moving up slowly then quickly like before and it hasn't happened again, however, I have not noticed condensation on the ground either. I was able to reproduce the problem last week, but this weekend after the car sat overnight the problem was gone, the condensation could have evaporated or slowly dripped out, So I guess we have narrowed it down to everyone's first opinion that it's the duck bill not draining at all or not fast enough.
I have read about the difficulty to access the duck bill. Any suggestions, I really don't want to drop the transmission, but I better do something. I read the post that he accessed the tube from within the engine compartment, I expect with a hanger. Any pointers.
Received 2,012 Likes
Duck bill has been compromised. I located the hole where the duck bill is located, ran the air a little to see if conspdensation would begin to drip, well it did become a little bit wet but not much. I took a metal rod bent the tip around two inches from the endi also sharpened it to a point and about a1/2 inch cutting edge. So as I slid the point up unto the hole, I was able to feel it puncture into the duck bill and then as I twisted the rod I felt is tearing and slicing, I did this a few times and immediately there was a nice puddle of water under the vehicle. Think it's fixed.
That's true, condensation is flowing nicely now.
So I have not experienced the smoke or steam again, I noticed when I do dial the fan all the way up to the highest level, I can audibly hear the speed fluctuate slightly. Is that normal? Again the apparent smoke did not smell like anything like burning. Is the fluctuating speed normal or could something not working properly.
The fluctuating speed and the rest of your issue sounds like the control module (aka resistor). Since you had the duckbill issue you likely had water running over the fan and module for who knows how long. The fan could be binding as well but I wouldnt start there. Not necessarily cheap parts but super easy to change: up under the passenger footwell. Jac
07 2007 Jaguar XK Blower Motor Resistor - Climate Control - Standard Motor Products - PartsGeek
https://www.google.com/search?source...0j0l4.5591j0j7
Bobioknight (08-27-2016)
