Dash lights/AC error/stuck in park
Do you drive it daily? If not, do you plug in a battery tender? If not this could be your issue. Charge up the battery and most likely all will be good. A jag that is not driven daily must be plugged into a tender, these cars are tough on batteries when they sit even for just a couple days. A battery that tests out good can still be suspect. If the battery is over three years old and the car does not get driven daily or get plugged in daily do yourself a favor and replace the battery, then put a tender on it.
Meh, some of us (like me) used to own that model - same year, in my case. A suggestion for you: I fitted an Odyssey battery to my XK8, PC1350 I think, and never really had battery issues again. It's a little smaller than the standard battery, so you need some washers to pack the battery clamp screws and get the clamp tight. Be careful lifting it in, though - damn thing weighs a ton.
1964Daimler
09-09-2015 11:28 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
