Dash warnings, battery replacement, and module faults oh my!!
ralphwg (05-12-2024)
I wonder if they just dont have a SDD, and they would need to use some other tech that doesnt work as well. You would think if they had functioning SDD updated to at least 2015 they could program any 2015 or older jag using that technology??... The instrument clusters are available online at jag parts stores new so....
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
sounds good!! While there tell the Jag Engineers you need “live access” to fix all 2015 and older jags on the SDD!
ralphwg (05-18-2024)
#28
My original post, offering some help if your cluster totally fails, was to generally say that as our vehicles get older then modules will eventually fail, but with the knowledge of fellow board members existing/salvaged modules can be utilized and or repaired.
Regarding your instrument cluster. SDD can configure a new or existing module. Whilst I have used SDD to configure an existing instrument cluster module I highly doubt that will solve your issue. Configuring a new cluster can be done but your mileage will be discrepant, only authorized dealers with JLR engineering involvement can transfer mileages to a new cluster.
When starting the car up for a split second the gauges quiver and do not respond then go up and function normally. So I bought a car code reader to see if anything was coming up:
1- intermittent : lost comm with instrument control panel module
2- intermittent: lost comm with body control module
3- intermittent: lost comm with information center A
I've sent you a PM so we can discuss further.
Yeah I got the same thing about the SDD. It’s obsolete and you may brick the car. I don’t understand. I got a 1997 mac and yes it’s obsolete but the computer as is, without updates, functions and still use its peripherals….. so why wouldn’t they be able to use old SDD to program new old stock to work in old cars?!? Did they yank them out and throw them away?
#30
no can’t find a browser that will work well with the system anymore…. Sucks
Biff Baxter
02-19-2022 11:39 AM
weltidave
09-13-2021 03:23 AM
