Dashcam Power Location
I'd modify what's been said slightly, as I see a slightly different set of happenings on my 07 XKR.
The 12V point in the ashtray does stay live for some period of time after turning the ignition off. I've never watched it to see how long it stays active, but it does stay active. My ADU is plugged in there and does stay running after the car is shut off. I usually pull the usb adapter to shut it down.
The glovebox 12V point operates differently. It DOES shut off as the ignition is turned off (and start up with the ignition being turned on). I have a radar detector plugged in that point and it goes on and off with the ignition.
Since the OP has an 07, this may give a more accurate set of happenings for his car.
XKRfangs
04-04-2021 09:53 PM
