Daylight Driving Lights
hi all
I have a question about the logic behind the Daylight driving lights logic that was installed in XK up and including until 2011 (after 2011 the faceliftes XKs obtained proper day driving lights, ie. specific lights for day use).
Until 2011 the XK does use the normal beam headlights as day driving lights. Due to legislation in my country my 2011 XK has the normal beam headlights on when the engine runs, even if the lights switch is “off”. My car also has the infamous AFS or what ever the name is: the lights that dynamicly follow the road.
Because in my car the normal beam lights are on even if stalk switch is off, what is the difference whether I have the switch off, normal beam head lights or on Auto? The head light are on in all these three switch positions. Does it make a difference for the AFS?
best
ter
best
ter
Br
ter
thanks. Good point. I just went to the garage to check. The tail lights are on even when stalk “off”. I still need to check when driving, but I believe that on “off” the AFS is not active. It is only when normal bean on or Auto. Btw - same thing for the rain sensor for the wipers: only active when the lights are on Auto, right? I tested it today and the wipers seem to be strictly time triggered when on intermittent and light not on auto, which I find good, because often the sensor wipers are not doing exactly as Iike.
Br
ter
I wonder if one of the differences in Canadian, Scandinavian or Polish DRL option is the tail lights... You say that your tail lights are on during the day? I will have to confirm but when I turned my DRL on I chose the Canadian option and I don't believe my tail lights are on during the day...
That is not correct. In markets (such as Canada) which require DRL , Jaguars have ALL exterior lights illuminated, front, side and rear regardless of the position of the lighting control (unlike other makes which often have only the front lights on). So in a Jaguar it is not necessary to touch the light switch; it can be left in the OFF position, with one caveat: in Jaguars built for 2005 and later, the dash lights are not illuminated with the DRL system (and therefore at night the switch must be turned on). But Jaguars built before 2005 have all lights, including dash lights, on all the time. My wife has been driving her X-Type for 15 years, day and night, and the light switch has been in the OFF position all that time - never touched. On my 2005 X-Type wagon I only have to touch the light switch when I need to illuminate the dash instruments. All these cars have AUTO lighting systems but that is redundant in DRL markets.
edit: so I did confirm that the Canadian DRL option turns on all lights including rear. I also confirmed that if you leave your stalk in off position the AFS is not activated. So if you want AFS, stalk has to be on or auto.
I think the OP is asking if it is necessary to turn the lights on to get the full effect of the entire lighting system if the DRLs are on during the daytime. I that the answer to the question is to put the light switch in the stalk to automatic and you will get the best of both worlds. The DRLs will work in daylight (no interior lighting). And when the lights get turned on automatically at dusk the interior lights will automatically light up along with the green Icon on the lower right of the panel in front of the driver.
I think the OP is asking if it necessary to turn the lights on to get the full effect of the entire lighting system if the DRLs are on during the daytime. I think that the answer to the question is to put the light switch in the stalk to automatic and you will get the best of both worlds. The DLRs will work in daylight (no ior lighting). And when the lights get turned on automatically at dusk the interior lights will automatically light up along with the green Icon on the lower right of the panel in front of the driver.
Dear all! Thanks for shedding light onto this subject. All clear now. I was interested in this amongst other to find out if AFS can be deactivated in some way. Reason: to only use it when needed ie. not in daytime- to reduce wear&tear on the AFS mechanisms, as failure here can result in very costly light replacement.
Br
ter
Br
ter
While the workmanual confirms that Canadian DRL does deactivate AFS in off mode, it is silent to this for European DRL.
For my car I can confirm that AFS becomes active even in off mode. Unfortunately. But it seems it does so only when dark outside. Not 100% sure, but this is what I experienced driving around yesterday in my XK 2011.
br
ter
br
ter
