Daytime Running Lights DRL Question 09 XK
XKGuy,
Welcome to the Forum! You'll find lots of helpful info here.
From the Insurance Institute for Highway Safety website: (here's the link:IIHS-HLDI )
"Laws in Canada and many European countries require vehicles to operate with lights on during the daytime. Canada requires vehicles made after Dec. 1, 1989, to be equipped with DRLs. The European Union requires DRLs for new cars and small vans under a law that took effect in February 2011. New trucks and buses in the EU must have DRLs starting in August 2012.
No U.S. state mandates DRLs, but some require drivers to operate vehicles with lights on in bad weather."
From the 2009 Owner's Handbook:
Daylight running lamps
(Canada only)
In certain countries it is a legal requirement for the lamps to be on during the hours of daylight. With the rotary collar in the OFF position, low
beam headlamps, side lamps, tail, number plate lamps and, where fitted, side marker lamps will switch on automatically with the following conditions:
• The ignition is on.
• The vehicle gear selector out of park.
• The parking brake is not applied (is released).
Although equipped with DRLs, they apparently don't work automatically on USA 2009 models (with the rotary collar in the OFF position) as they do in Canada. I think you have to turn the rotary collar to the ON position for the DRLs to work. I haven't checked my 2009, but will do so soon.
Owner's Handbooks are available online: TOPIx - TOPIx
1. Click on your language (English)
2. Scroll down to United States, click Select
3. Select XK/X150 from dropdown box
4. Select Model Year (2009) from dropdown box, click Find
5. Click Owner in upper right corner
6. Click Owner's Handbook in upper left corner
7. Click topic(s) of interest on left side
Hope this helps!
Stuart
(Canada only)
Hope this helps!
Stuart
XKGuy (01-17-2013)
XKGuy,
(Canada only)
Hope this helps!
Stuart
(Canada only)
Hope this helps!
Stuart
I put a small piece of black tape over the front of the sensor on the dashboard and leave the rotary knob in auto. The lights think it is night all the time and come on when the ignition is on. Don't even notice the tape, took 15 seconds and cost 0.003 cents for the piece of tape.
Best to all,
Best to all,
Deabs (12-22-2021)
Deabs (12-22-2021)
Yup, could leave the lights in the "on" position. However, when you shut the car off and open the door you get the chimes that something is amiss. Now you need to manually turn the lights off or I suppose leave them on and walk away. Perhaps they'll eventually turn off but now one is using battery power which I've found is not the wisest thing to do with one of these chariots. With my tape over the sensor, ignition on lights on and ignition off lights off, with no chimes. I believe this functions similarly to DRLs.
And yes, I do want my taillights on. In my opinion I have less reaction time and options to the stupid drivers behind me than I do to those in front of me.
There are any number of ways to skin the proverbial kitty. Mine works for me and it might not for anyone else.
Warmest regards,
Warmest regards,
Best to all,
Best to all,
Great post! Would u mind posting a picture where the sensor is on the dash?
Thanks in advance!
The sensor is the little nub located on the top center on the dashboard close to the windshield. The rear half of the sensor houses the red flasher for the security/alarm system. The front portion of that nub is the light sensor for the auto headlight function.
I put a small piece of black tape over the front half yet the red alarm flasher is still visible. Since the area where the sensor is located is black, even on my caramel (tan) interior, the tape is virtually invisible.
If this minor league attempt of an explanation is not clear please PM me.
Best regards,
v8deuce (09-24-2017)
Had my DRL turned on by dealer
I had my DRL turned on by the dealer because it is the law in Canada. My 2011 XKR 175 was bought in the US. The dealer took about an hour to do the job. They had the hood up and the battery access area opened up. I thought it was just a matter of programming? Then they washed the car and made a mess of it. Anyone know why they needed access to the rear battery area and open the hood up? They charged me around $150.
Sorry, am not tech savvy enough to post pictures.
Best regards,
Best regards,
Not sure it pertains to our cars, but i did find it interesting to see it doing "double duty".
Vince
