dead battery
I have a 2008 xkr vert. I left the charger at my other house a week ago. It started when the screen wouldnt come on. I just went to the garage and the tail lights were dimly lit and the start button was illuminated. The battery is almost dead and none of the trunk open options (key, tab etc) work and when I bought the car I didnt get a trunk key. Any ideas much appreciated.
Remove the emergency metal key from your SmartKey fob. There is not a specific trunk key. You can use that to unlock the trunk...keyhole is to right of license plate.
Positive charging terminal is behind the louvered panel on left side of trunk. Minus charging terminal (chassis) is under trunk floor next to spare. It is safer for the car to charge the battery for a while rather than jump start if you can.
carlprs (05-08-2014)
It will probably need a few hours unless it is a high amperage charger.
Are you underneath or did you get in the trunk?
Guy-Pierre Boucher
09-16-2015 05:55 PM
