Dead battery / can’t access
Received 1,975 Likes
can I put my charger on it and leave it over nite , instead of boosting it
Put charger on , and used the quick boost start on it , all kinds of lights come and warnings like apply brake , and other warnings on the display but won’t start or even turn over , it seems like it’s looking for everything to run thru cycle and reboot or reset I,m getting flustered, there is lights flashing as I’m charging it as well ,
I really appreciate in put , put charger on and I have a setting on it for a fast charge and trickle , put fast charge all lights come on and horn went off then all kinds of warnings run thru the screen but won’t start nothing , there is some lights still flashing small ones two at the front two at back like my 4 way emergency ones , I put it back on trickle and it’s slowly going up and down amps 6 to 7 amps slowly going up a little , any other things I can try , you think boosting it off my other vechile might work know there is a place to hook up cables .Sorry for long winded question , love the car but at a loss .
The flashing lights and sounding horn on the XK is a classic symptom of a dying battery. Charging may work briefly, but you likely need a new *fully charged* battery. These are fabulous cars but they need full battery voltage for the multiple modules - or else they start to display perplexing and worrisome symptoms that can be in any electrical component or path.
XKRAU (03-25-2023)
