dead battery, top down, can't get to battery.
Jag XK* 2007 convertible, in garage, top down.
Battery discharged, car won’t start.
With the top down, can’t get to the compartment in rear to get to the connection point on the battery.
Dealer closed _ Labor Day
Is there any way to manually raise the top?
Hal
Hal
There's about a dozen or so threads about the same problem, look at them. Basically you'll need to find another electrical point that's connected to the battery and charge it through that. I'm pretty sure there's a positive post inside the drivers rear quarter for this purpose. Should be discussed in your owners manual.
benpearce2013
02-06-2017 03:07 PM
