Dead space in wheel at 12' o clock. Going in tomorrow
Old 02-15-2016, 09:59 AM
Lothar52's Avatar
Default Dead space in wheel at 12' o clock. Going in tomorrow
Recently had some...that is ALOT of work done on my 12 XKR when one of the actuators started ticking. Jaguar OK'd the work to remove the tick and they had to drop the engine, replace the chain, and then the chain tensioners were not working again so replaced them as well.
Picked the car up and everything was awesome... sounded great...they even took the "creak" out of the wheel when turning the wheel at slow speeds heard best when backing out. However i noticed at 12' o clock there was 1-2 degrees of play where it felt like the steering wheel was moving but the steering mechanism wasnt - just no resistance at all. I thought well i will give it a few days to see what i think...
The worst came at 70mph on freeway. Small degrees of adjustments are needed to keep the car under control and i thought i was moving the wheel a ton to keep it straight.
someone told me with know-how its like just a "loose pinch bolt for one of the joints". Im hoping thats just it. Ever have this happen to your XK?
Loth
Old 02-15-2016, 07:53 PM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
Hey Loth,
So happy you got your car back, it's been a while, and I've been checking the posts each day to see if Jaguar fixed your problem. While I have not had that play in either of my XKRs, I have had that on my '72 Pantera, and with manual steering, you really notice it. It is something that will be fixed on my car during its engine/fuel injection transplant over the next couple of months. However, in your case, it certainly seems like some kind of adjustment, especially in light of how many times your engine has been dropped into and out of your car in recent weeks. Take it back and let them fix it, and be happy!
Lothar52 (02-17-2016)
Old 02-15-2016, 08:50 PM
flyc2c's Avatar
They didn't tighten something. Bring it back ASAP.
Old 02-16-2016, 02:06 PM
Lothar52's Avatar
Yep took the bottom cover off the car, tightened both pinch bolts on the rack and pinion and it's as good as factory new .... so so happy!!
DGL (02-17-2016)
Old 02-17-2016, 04:43 PM
Lothar52's Avatar
Originally Posted by tberg
Hey Loth,
Thanks brother! yep all is good now... Sounding good, feeling good, driving good . Finally got all 3 covered!!
tberg (02-17-2016)
Old 02-17-2016, 08:03 PM
tberg's Avatar
That's great! Mid-90's for the past week here in Los Angeles so it's hard to imagine. Was using my convertible as my coupe was in the shop for some work, but too hot to keep the top down, believe it or not. Hopefully, you get an early spring.
Old 02-17-2016, 09:38 PM
Lothar52's Avatar
I hear ya buddy... now that its fixed, cleaned, and in the garage maybe I will get to drive it in oh... 5-6 weeks
Old 02-18-2016, 08:18 AM
Snide72's Avatar
Talking Bad News
While you were asleep last night, I quietly broke into your garage and started your XKR. At first it sounded great ... but then ... I heard a very distinct 'ticking' sound coming from the engine ...
Lothar52 (02-19-2016)
Old 02-19-2016, 09:30 AM
Lothar52's Avatar
would be just my luck!! DOH!!
