Dealer...*******s more like!!
About 4 mths ago i needed to replace my failing battery on the xkr. Went to my local dealer and they advised fitting an AGM battery. Great i will have one of those.
Took the car in the next day and they kindley fitted it for me. That was 4mths ago.
Imagine my surprise and extreeeeeeme annoyance when i look at the battery and find out that they fitted a lead acid battery all those mths previous.
I phoned them to ask for an explenation and all i got was here in NZ they don't have AGM batteries to fit the xkr. Then why, i asked did they not say that when they fitted my battery. Waffle waffle and more verbal diarrehhea was the result.
Oh and if you fit an AGM battery they said, it would fry my system rendering my xkr useless. End of diarrhea!!!!
In the end i called my local battery dealer down the road. He had 3 on his shelf ready to go. Supposedly none in the country jaguar said.
In the end i got a refund from Jaguar and now actually do have a AGM battery in the car.
Thanks for reading guys. I had to share.
Cheers.
Cheers.
Thanks for the info.
I have just had the locking touch screen a couple of times so far but only in the first few weeks of ownership so driving it daily may have brought the battery back to life. I shall see what winter brings as that usually is the most challenging time of the year for batteries.
Best,
But then again, I will be having to pay for another $200 battery, so maybe I should reconsider!
The bigger issue right now is I don't have a garage (only a covered parking spot 1/4 mile away) and the weather is too cold and/or it gets dark too early for me to be motivated to get this issue solved.
