Dealer texting me info for service appointment
Yes Im old and definitely behind the times. But this is what kills our love of the automotive world. After seeing this I had visions of Lab Techs walking around in white lab coats.
Im gonna try SDD but my stand by OBDII laptop runs XP and it dosent install on that platform.
So, that Jaguar mechanic woke up the next morning and, to his surprise, found himself standing before the Pearly Gates! "Saint Peter", he exclaimed, "why am I here?" And Saint Peter explained that his time had come. "Oh no," said the mechanic, there must be a mistake - I'm only 45 years old!"
"Well", said Saint Peter, "I double checked my book, and according to your time sheets, you're 78! Welcome!"
Your situation appears to be different. The message trail suggests the vehicle has been in an ACCIDENT and has unspecified electrical issues. If this is correct, no shop could possibly estimate for the time or cost prior to some preliminary investigation.
SDD was designed to run in Windows XP. Around v1.50 Windows 7 became the recommended OS but it would still run on XP. This was the last 'full' version with SPA and VDF files included. Windows 10 was added from v1.58. If you are intending to try diagnosis yourself before using the dealer (and I would most definitely take that approach), then v1.50 or earlier will be suitable.
Where do I pick up a v.1.50 ?
Send me a PM if you want to do this. I don't want to post links on the open forum.
V130 is sufficient for your 2007 car.
You can also run SDD on a virtual machine Windows 7/XP if you have a more modern computer with a later operating system. My V130 is running on an Intel MacBook Air with a Windows 7 VM.
In addition to the dongle, you will need a clean power supply to keep your battery at greater than the SDD minimum 12.6 VDC with about 40 amps capacity.
Uncle Fishbits
12-29-2021 05:18 AM
H20boy
01-17-2013 01:40 PM
