Decided it's time for the Exhaust Upgrade
So after reading for several weeks on different directions people have gone with their XKR's exhaust, I've almost got my mind made up on what direction I'm gonna go. The only thing I haven't made up my mind about is which high flow cats I am going to run. Both sets that I am looking at are 300 cell cats, which the main difference mostly being price, and one set being Jaguar specific which I like. One good thing the PYPES cats have over the magnum, is the fact they are made of a metallic material on the inside which is supposed to be designed more for forced induction applications. So I'm torn on which direction to go.
https://www.magnumtuning.com/en/deta...ion/jaguar/xkr
or
https://www.rpmoutlet.com/1986-2014-...-substrate.htm (these are universal not Jag specific as you can see)
I'll be running one of these, removing resonator, adding an X-pipe towards the back, and keeping stock muffler setup with fuse 19 pulled. Has anyone had any experience with either of these style cats, or any advice on which may be the best direction to go? Thanks in advance!
or
Keep in mind you need to tune the ECU properly for the high flow or decat. Otherwise you will loose power down low and set a check engine light as well.
Also from my own experience h,f cats that I bought lasted less than 7500 miles before they melted , so quality of aftermarket units is in question. And yes the ones I bought were metallic inside
If you're looking for sound only he should just remove the silencers or change the rear box.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
I can help with the tuning
__________________
Once I get it all installed, and see if I have any issues with CEL's/power loss, I will definitely appreciated the help with the tune. Hopefully whichever cats I go with won't melt on me too. Surely that can't be a common issue with a lot of high flow cats on these cars.
mosesbotbol (05-07-2020)
There's not that many of these cars that are running with high-flow cats , just of top of my head I know another guy had with a Jag with high flow cats and they have melted just like mine did. Google issues on running with aftermarket high flows, tons have melted. That's why I'm running catless. A tune btw can be done for performance not just cat cel removal power loss . I'm At near 100 gain to the crank on a 4.2 car ,5.0 has even higher potential tuned
I considered catless, but was bombarded by people telling me I was inconsiderate for even speaking of such on here. So I opted to just run some high flow cats, plus I don't want a lot of drone inside the car. As far as tuning goes, I've had plenty of my cars dyno tuned, but not many places offer this for the XKR's and the ones you can order are more than I want to spend just to tune in some cats.
And once again if you're just looking for sound I do not recommend going with high-flow cats or decat because most likely you will get a check engine light and most likely you will loose power on the low to mid rpm range , from my experience these issues must be addressed in the tune.
I I shelled out $1,200 4 high flow cats to have them fail at 7000mi, so just keep that in mind.
Well there is not a lot of tuners that actually do jaguars properly. You can check my past threads on my journey , I went through several tuners with bad results , fast forward three years later I do tuning for the XKR cars myself and for others and I have pretty amazing results ! Feel free to pm can provide my cell if you want to chat on the phone .
I have the same brand 100 cell cats and mine have not melted...yet. This usually happens with fueling or timing issues. Also in my opinion I do not think there is much acoustic difference between straight pipes and 100 cell cats. Also drone comes from exhaust design and mufflers, not catalytic convertors.
I would look for a complete solution from one of the companies that really know Jaguar. Certainly not the cheapest route, but may be the smartest in the long run.
I put two high flow mufflers on my XK and it was such a dog down low, I swapped them back to OEM within a week of the install. Biggest waste of money ever. I learned my lesson.
I would go cat-less and not mention it to those easily offended.
EnRoute30 (05-07-2020)
It’s loud but not as loud as some I have heard. I can play music and make phone calls in the cabin without too much interference.
mosesbotbol (05-09-2020)
