Delayed acceleration in D mode
Old 12-22-2017, 11:08 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Originally Posted by 110reef
Mine appears to start out in 2nd as well, based on the display. Whether it does or not I don't know. I have never counted the shifts.
When in Manual Mode, the car WILL downshift to second to avoid transmission damage. We're all talking about when in Drive and Full Automatic. No Paddles at all.
Old 12-22-2017, 11:22 AM
110reef's Avatar
When in non-sport mode, the display only shows D, When in sport mode, automatic, it show all the gears. It normally goes to 2, not 1 on the display.
Old 12-22-2017, 11:25 AM
Tervuren's Avatar
If it is showing gears in sport mode, you would of hit the paddles to engage manual mode.
Manual mode still will shift at red line, and at a minimum. If you saw DS that is sport mode, the numbers are manual mode.
Manual mode can be activated from both DS and Sport, but DS will hold the manual mode once activated, drive will time out and revert to drive.
Old 12-22-2017, 12:33 PM
110reef's Avatar
You are correct. I stand corrected.
In sport manual mode, it will take itself down to 2, but not 1.
Sorry for my confusion.
Old 12-22-2017, 04:08 PM
Robman25's Avatar
Originally Posted by Ranchero50
46, old enough to know I'm not as good as I once was...
Ah just a spring chicken then
Old 12-24-2017, 12:05 PM
So Sick's Avatar
Just had my jag 2003 xkr with same problem slight lag at take off. thought it might be a fuel pump or fuel filter. They found the mass air sensor was reading incorrectly thus the problem. Haven't put in a new mass air sensor yet. will advise if that fixes the problem
snoack321
07-05-2021 06:14 AM
gchin
10-08-2020 01:43 PM
tnt10
09-24-2017 03:03 PM
princemarko
05-04-2013 06:52 PM
cadrad
09-24-2009 01:27 AM
Quick Reply: Delayed acceleration in D mode
