DI misfires...my saga of frustration
2010 XKR 5.0, 75k miles.
So, as some of you may have seen my 75k mile carbon build up thread. What started that endeavor was a cylinder 7 misfire/restricted performance.
I started with plugs. Put new plugs in. No change. Swapped coils around. No change. Got pissed and ripped off the supercharger, cleaned the intake valves, put 8 new injectors in. Start it up today, have cylinder 2 misfire (#7 misfire is fixed) . Swap coils with 1, no change. Swap plugs with 1, 2 looks brand new unfired almost, 1 looks fired.
Does anyone thing that brand new injector is faulty? Or could there be another explanation for this.
Queen and Country (08-14-2018)
Yep, and there's a special tool to first stretch the seal then another one to shrink it back down in two stages.
I feel your pain. While it is possible that brand new injector is faulty, when you heard hoofbeats, think horses and not zebras.
Have you considered that this issue may be fuel pressure related and not injector related? If one of the second stage pumps is marginal it can wreck all kinds of havoc with DI and look like injector's fault.
Misfire cyl 2 seems to stay constant, along with misfire detected within first 1000 rpm code. The other cyl misfire codes come and go as I switch. Out of state at the moment but when I get home all new coils will be waiting, so if at the least I hope I can rule out a bad coil. I'll have a new engine before too long!
What is strange is this whole thing started with #7 mis-firing. Then after all of the work it's now at #2. Hard to believe a new injector would be bad but you never know. Did you or can you use a noid tester to see if there is power to the injector. Also when you pull the plug what does it look like. Dry or wet . As I said something strange going on.
TXFireblade (08-18-2018)
