DI misfires...my saga of frustration
So lean condition and a dry plug seems to indicate that the injector is not firing. So 2 new replacements and same condition so it rules out a bad injector. Is it possible you have a bent pin in the connector. It just seems localized to one cylinder. Maybe a broken wire. A coil wire in the connector or a bad pin. Is it possible that both the coil and the injector are not firing. How do they both fire is it from a Crank Position Sensor. Good luck.
u102768 (08-19-2018)
#31
Depends on the diameter of the largest moveable section. Most likely where the injector fits into the fuel rail. Figure out the square inch of the opening and multiply that by the fuel PSI to figure out force pushing the injector out of the rail. Probably not too high in the greater scheme of things.
#33
TexasTraveler (08-23-2018)
#35
#36
The following 2 users liked this post by 10XKR:
Cee Jay (08-23-2018),
Ranchero50 (08-23-2018)
#38
#39
The following 7 users liked this post by bigdhenderson:
Cee Jay (08-24-2018),
jahummer (08-25-2018),
ralphwg (08-24-2018),
Ranchero50 (08-25-2018),
Sean W (08-25-2018),
and 2 others liked this post.
#40
