Anyone know (physically) what the differences are between an XKR and an XKR-S?
Also are there any physical differences between the engines for the 2012 and 2015 model years?
I ask because the 2015 model year shows as having more horsepower, and the XKR-S even more so. I'm curious if the difference is just ECM/EXU programming.
Catfish bumper on the XKR-S with 575bhp and will do 184mph
No difference I'm aware between the normal 5.0xkr from 09-14 which all run at 503bhp excepting some (like my dynamic R) have speed pack to raise the limiter to 174 IIRC
As I understand it the "-S" identifies the last build of a model series prior to a retool or major model overhaul.
Then you understand incorrectly.
The -S is the more "Sport" model. It comes with uprated suspension, steering and engine tune. Also some aero if I remember.
Pray tell...what's uprated steering, or indeed a steering tune*?
My XKR has the same suspension as an XK-RS IIRC without that IM(less than H)O awful front end
*If a difference perhaps I'll get the rack from a nearby breakers...I love a good rack me!!
no specific detail in this thread about what exactly is different about the suspension, but, multiple confirmations that it's stiffer. that improves steering. i would wager the scrub radius is a touch more aggressive.
also! excellent cautionary tale in there about carmax that bears repeating anywhere. avoid at all costs. whenever i see a facebook or nextdoor thread that consists of "where can i sell my crappy used car?" whether they write it that way or not, dozens of people chime in with "carmax."
Agreed Jons, despite CJ's attempted pointer there was nothing that said 'the XKR-S has a modified steering rack', and google as I might I can't find an answer.
Mine does have powerflex black poly bushes (stiffer), wortex discs (reduces unsprung) and yellow Bilsteins (same as XKR-S... normal 5.0 XKR's had black or green IIRC?) an X pipe and no back box.. Plus I have MICHELIN PS4S's which weren't available when the RS came out. Don't get me wrong I've no desire to track. But suspect if I were to drop a tune on mine I'd be exceeding an RS's performance and handling by some margin...plus I now weigh in at less than Lewis Hamilton's racing weight and don't know many XKR owners that can say the same
So am still none-the-wiser, perhaps a deflection for the red herring?
Anyone with a RS care to contact their dealer and find out the part number for a replacement steering rack and I'll do the same and compare part no's fr clarity?
*sigh*
It's sad some people are so ignorant.
Marky, I never had a problem with you before, but now you seen to have turned into a hateful person and for some reason specifically aimed at me. I'm clueless as to why this happened.
Sad to say this, but I shall now add you to my IGNORE list where you will be only the third person added in my nearly eight years of membership.
Have a good day, and goodbye.
XKRS and XKR dynamic r share the same steering rack. It’s different than XKR and XK.
AFAIR 2 1/4 turn each side vs 2 3/4 in XKR (a bit faster, more sporty rack vs limo style in XK/XKR)
