Differencial Fluid
Received 1,103 Likes
Any Ford spec M2C-192A synthetic will do.
You do not need to add a friction modifier or a viscosity control fluid.
There are a few brands that excel at low temperature and high temperature flow and lubrication.
RedLine, Lucas, RoyalPurple have good reputations.
I change mine every 50k kms, along with the transmission fluid and pan.
V7Sport (01-25-2024)
Any of those brand name gear oils would be fine. I used Valvoline. See this link for my experience in changing the diff oil.
https://www.jaguarforums.com/forum/x...4/#post2251156
On the 2008 XKR diff, not sure if the XK is the same. There is no drain plug for the diff oil. So you either have to remove the diff cover or suck the oil out from the fill hole. I'm running 75w-140 Amsoil severe gear oil. If you are going with the sucking the oil out method, make sure the fill bolt can be crack loose. Go for a spirited drive and then suck the oil out. Its easier for the thick gear oil to flow when its nice and hot.
guy (01-26-2024)
Yes, whether an xk or xkr, ‘07 -‘09?? were not provided with limited slip differentials.
You had to upgrade to an Aston Martin for that feature ;-). Or do what was suggested above, source a Quaife LSD,
and due to its mechanical nature, a improvement in my mind. (That should get this forum active, lol).
Spec (workshop manual) defines 1.25 l.
Some try to be smart, lookup the FoMoCo reference and state that volume. The problem with that is they have not taken into account the custom rear cover.
Volumetric expansion occurs here due to heat. Don’t overfill!
XKRAU (02-01-2024)
FoMoCo offers the engineering for this on thier truck maintenance site but, this is a fair “readers digest” assessment:
https://newlygen.com/2023/09/21/can-...rential-fluid/
Richard
XKRAU (02-03-2024)
