differential clunking
Well I think I done gone and f'd myself.
I changed the fluid on my diff for the second time (no issues the first time, same fluid - Valvoline 75w-140 synthetic). Changed it the other day, then I took a 1000 mile trip to VA and back.
Now I'm noticing a clunking noise from the diff when I turn at low speeds. Nothing at higher speeds.
I'm guessing I didn't add enough fluid back in? Am I screwed or can I try adding some more fluid? Will the diff fail completely and lock up at some point?
Maybe a dumb question, but did your fluid include a friction modifier? If not, I would change it as soon as possible to an LSD fluid with FM..
The following 2 users liked this post by Cee Jay:
MarkyUK (08-13-2021),
steve_k_xk (08-12-2021)
I am going to try that bar leaks gear repair stuff and see if that works.
just look up 2003-2006 lincoln ls 3.9 rear carrier
Sixx Dogg
03-14-2010 08:50 AM
