Differential Help
Welcome to the forum Sherard Big Daddy,
I've moved your question from General Tech Help to XK8/XKR forum. US based members here with the same model will be able to help.
Have a look in this thread ==> https://www.jaguarforums.com/forum/j...ntials-134733/
Your XKR has a 3.31:1 ratio diff which was also used in the S-Type, X350 XJ, early XF's and even the Lincoln LS & Thunderbird.
Hopefully that might help you in finding a second hand unit. In that thread I mention which engines of which models got which ratio's.
If you have a capable workshop nearby then I would also suggest taking the diff and driveshafts from a 1999-2002 S-Type (3.31:1), fitting a Ford 8.8" LSD to that diff, and having your workshop sort out the driveshaft lengths.
Will be much cheaper in the end than the $7000 or whatever Jaguar insists for the upgrade kit to the GKN differential, which is still an open-center.
Good luck with it.
https://www.jaguarforums.com/forum/x...lation-155867/
If you can get it out yourself you'll save a ton of money. I'm in Atlanta if you'd like to PM me.
Gopi Hira
01-25-2016 11:22 AM
PopokI09XF
01-20-2016 06:40 AM
