Dim dash cluster
I bought a T-bird decades ago and I couldn't see the dash for nothing (had the new and fancy digital speedo). I went a week complaining, then I noticed the dash pad that was on it. Sure enough, it blocked the Light Sensor. I cut a hole and it worked perfect after that.
No, without the dash pad the glare was horrible. It had a beige leather dash that reflected terribly in the light.
Dim cluster
The dash cluster between the speedo and tacho is dim and practically unreadable when the car is first started. After about a half hour drive, it comes bright and remains that way. I have replaced the switch cluster with the dimmer switch but no good. Any thoughts? Dennis
