DIY Coolant flush
Here's a link to the workshop service manual you can download @ no cost.
http://www.jagrepair.com/images/Auto...XKworkshop.pdf
MarkyUK (09-18-2019)
If you are referring to the purple drain plug, that is on the engine block, driver's side (LHD cars), near the exhaust pipe leading to the catalytic converter.
If you are referring to the blue drain plug, that is below the radiator.
Those colors are to highlight the drain plugs in the photos, don't expect the actual parts to have those colors.
I would say it is sufficient to drain the coolant from the radiator and forget having to raise up the car sufficiently to get under the engine so you can remove the purple drain plug.
If you only drain through the blue plug (bottom of the radiator), how can you do a complete drain if there is still coolant left in the block?
Also, thanks for the tip about the vacuum kit. I had never seen one of those before. That looks even better than I bought a few years back.
Thomas
