DIY oil change on 2011 XKR
You'll need a vacuum pump, as the oil is removed through the oil filler cap tube. If you don't have a pump handy, you'll have to pay to get it done. $200 is quite ridiculous though. I pay $86 for full synthetic and a Wix filter at a local European Vehicle Specialist place. Of course, they don't do everything a Jaguar dealer would do, but most of it. I do the rest. My closest Jag dealer is well over an hour away.
Many people have used the conventional drain plug in the oil pan to change the oil. Since the Oil filter is located on top of the engine I find it easier to use a 12V electric pump that I got on Amazon for about $27. It pulls the hot oil out faster than I could lift the car. I did have to get a short clear plastic tubing from Hope Depot to fit the car's suction tube.
I ordered a 12 Volt oil-specific pump from Amazon for I think $29. It works great, but the leads on it are worthless with the battery in the boot. I use a spare battery I have lying around to run it. Just have to make sure the oil is somewhere near operating temperature and not a cold sludge or it will work the motor too hard.
