Does the subframe look ok?
Also if there is some rust and parts need to be replaced, would it be expensive? For instance replacing brake pipes isn't expensive.
George05 (06-04-2020)
Rust is not necessarily an "issue" unless bits are disintegrating from it but it does give you an idea of where the car has been or possibly water damaged. But what else I saw in the pics was more of a concern to me than rust, the "wet" areas look like possible leaks from the differential or suspension or elsewhere which would warrant further and careful inspection. As noted though it could just be a coating.
Comments from MOT were:
Suspension unit corroded but not seriously weakened Front (components)
Break pipe corroded, covered in grease or other material Nearside Front
Break pipe corroded, covered in grease or other material Offside Front
Sub-frame is corroded but structural rigidity is not significantly reduced
so I’m guessing it’s cheaper than similar (looking around) but not absolute bargain. Have to say I’ve never looked at the underneath of a car before when I’ve bought one but then again I’ve never spent anything like that.
a lot will depend on what AA mechanic says.
