Doesn't everyone own a code reader
In low voltage electronics any spurious signal may cause undesirable interference in the operations of connected circuits.
I am not an expert in automotive electronics but, I can easily see how a device, that in various states of operation could present a certain impedance to the car's computer circuitry, would trigger a transistor, causing unexpected scenarios.
OBD Is a well defined standard. The chips in the readers are pretty standard, and I would not be surprised to see the same chip in a $200 reader as a $11 reader. Yes... the quality of the circuitry may vary... and I actually agree with you that leaving an ODB reader plugged in 24/7 may cause an issue in some cars (including battery drain). However, I would not disuade anyone from buying a well reviewed elm based reader to diagnose a problem with their car. Dealers are in the business to make (aka take your) money, and a well informed customer and his money are less likely to be taken for a ride.
Exactly. Happened to me with my 2013 XJ a few months ago. I left my ELM327 OBDII reader plugged in when I shut off the engine. The next day, when I started it up my dashboard went bonkers with one error message after another. My Jaguar service adviser told me to always unplug that OBDII reader and not worry about all those error messages. No codes were reported and no more error messages.
Nobody mentioned mongoose cable,through it is not a simple code reader. It's a J2534 diagnostic cable. The Mongoose JLR is one of the new approved interfaces introduced by Jaguar who are dropping support for VCM. It is a cheap good quality cable covers all obd reader functions.
Received 1,442 Likes
Well EJ . . . actually they have! Read posts #2 and #14 here . . . and, by no means an accurate count, but at least hundreds of occasions over many dozens of threads identical to this . . . but it seems repetition is good for the soul!
Some learn; some ignore; and some deny . . . but the nature of Jaguar Forums is that each may weigh up the advice offered, then please yourself. What all of us should try to guard against (and in this, I support JagV8), is the advancement of "urban myths" - in this case, the wholesale denigration of low cost, proven OBDII diagnostic aids.
No-one here should deny the right of others to form and hold whatever belief . . . even in the sacred realm of maintaining your Jaguar! But, please take great care when you begin to advance those beliefs here as technical advice to others. Quoting Google based and "other internet sources" as "evidence" per se without case specific examination is like relying on Wikipaedia in the face of its own oft repeated warnings of "citations required" . . .
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Ken
#28
cat_as_trophy (03-18-2016)
JessN16
12-13-2015 02:34 AM
