Dog whistle high pitched whine from A/C
This is a topic, noise, whine whistle, squeal, etc, I have seen come up a lot here with all sorts of diagnosis and conclusions but no REAL conclusion from what I can tell. The noise is present ONLY when the compressor is engaged, with the climate control on and in econo mode (compressor off) the noise instantly goes away, turn econo off (compressor on) and the whistle returns.
The whine has been present for about 5 years but only occasionally and typically was only under hard acceleration. Recently though it seems to do it more frequently, some times continuously for an entire drive and sometimes not at all.
Has anyone come up with a solution? Thanks!
Rogerj (07-18-2016)
I can't find the link now, but I had read that there was a TSB that replaced a bend going through the firewall. Though I recall that being for the 5.0. It was certain loads and temperatures could cause it. Had to do with the flow of the coolant. I had seen reports of topping off the refrigerant had helped solve it. I was going to try that and then track down the new bend if not. Hadn't seen anyone posting reports of doing it.
jahummer (07-10-2016)
Not the gearbox as the noise goes away when the compressor is turned off but blower left running. I'll check with a Jag dealer to see if they have any ideas.
I had this exact same problem. High pitched whistle that could only be heard when the a/c compressor was engaged. Had it for months and it slowly got louder or at least seemed to. At first I didn't notice any issue with the a/c other than the whistle, but over time it seemed to not cool as well. Eventually it stop cooling completely and the whine stopped. Turns out I had a leak in the evaporator. Assume the whine was caused by low refrigerate and was gone once I had the repair and recharge.
Drove the car a bit this morning. Note that it took about 10 minutes for the noise to begin. AC blows ice cold from 70f and below in this hot Florida sun. Also noted the throttle affected the noise as well. Coasting at 20MPH the whine was present but as soon as I lightly pressed the gas pedal, the whistle went away.
Jaguar XK 2010 - High pitch sound coming from left-front drivers area. I thought it was a window leak, or a the left-front brake pad, or a A/C sound, or a speaker. After some investigation, evaluated it wasn't a speaker. Not sure what it is. Comes and goes...
I have this exact issue. It's definitely aggraveted by outside temps, BTW. Brought it in to a Jag dealer (I have an aftermarket warranty).
A) they said since the replacement tube is not "original," it is not warrantied.
B) but they could replace it for $261.
"A" seems like bullshit, but if I lose that fight, is "B" reasonable?"
UPDATE: so I had my car in for something else, and I played Let's Make a Deal with my warranty company. They agreed to cover half the cost of the spacer-and-o-ring fix-- I'd be out of pocket $125, and figured why not.
So far, sound is gone. Didn't realize how annoying it had become til I stopped hearing it. Glad I had it done.
