Dongle for SDD
Ok boys got it to work I reinstalled the JLR SDD software that came with the dongle and once that was all done I plugged back in the dongle and then BAM it was working and I was in the menu. Everything is groovy now! I also forgot to add that I ran the patch that came with it and used the login credentials as well that was in the notepad. My main thing was to enable the AUX connection but was wondering what other options are there for us to take a look at besides troubleshooting?
I can't play anymore with it since the XKR went to the body shop to get the side rocker panel repaired as it was damaged during shipping. So once I get it back later this week I will get deeper into it.
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
Yes it was but what I can do for you is extract the cd's info and I will upload it to a cloud drive so you can download everything.
peterv8 (08-26-2020)
Ok I managed to upload everything for you into the Google Drive. Here is the link:JLL Software Download for J2534
Please follow these steps that worked for me.
1. First uninstall everything you have that is associated with the JLR SDD.
2. Then install the J2534 Device Setup V.4.0 which will install the associated drivers for the Dongle.
3. Once that is complete install the JLR SDD software.
4. Then once that is complete install the patch and use the associated username/password in the text file.
5. You will then need to enter a address, etc for everything but just select any country and put independent operator and any address and then you will get pass that screen.
6. That should be it and you should be good to go!
sproot (05-15-2023)
5. You will then need to enter a address, etc for eny, that was verything but just select any country and put independent operator and any address and then you will get pass that screen.
Tony, that was very kind of you. Hopefully your way gets it working for me. Thank you very much!
#30
#31
You don't need to install the vcredist_86 file. Just the DA J2534 Device Setup file.
AmDazed
26
07-03-2021 12:13 AM
