Door Panel Repair
I had thought about trying to remove the leather portion from the main card but it does not appear that it was ever meant to do so due to what appears to be molded plastic rivets(of sorts on the back). I also thought about making a small hole in the corner of the leather and injecting some contact adhesive to join the two together again but fear that the leather shrinkage may prevent an adequate fix. Has anyone else ever attempted the adhesive injection method? Or for that matter, ever successfully removed the leather from the main door card?
I wouldn't want to poke holes thru the leather though. I'm with pwpacp and CeeJay. Go to a Pro. It probably won't cost much.
I've seen another thread where someone suggested using Elmers glue - I did a test with no success.
Although I managed to get a few bubbles to stick back down using the syringe method and contact adhesive (which incidentally left no perceivable holes in the leather), I agree that it really needs to be removed from the substrate so the surfaces can be accessed for cleaning and re-glue.
This is what I plan to do next weekend.
The plastic rivet looking things are common over these cars - especially in things like the rear lights on the trunk , the overhead console and other places like the doors. They are actually just a melted and formed head on a plastic post. A small nozzle heat gun used carefully over the plastic head will easily soften it. I use a pair of needle nose pliers to reform the plastic into a post by squeezing on the sides of it until it is small enough to lift off whatever it is holding. When re-assembling, just reheat heat and flatten down.
mphilleo
XJ40 ( XJ81 )
12-16-2010 06:21 PM
