Door Parking Light Image Projection
Hi All, entertaining the idea of the jaguar leaper logo projecting from the parking lights on the bottom of both the driver and passenger door. I have seen this on some modern cars and like the look on the pavement as doors are opened.
Anyone have any experience, thoughts or recommendations on this? Seems pretty straight forward so far as installing any kit that might be available. I have a 2008 XKR Convertible. I do not think this will affect the stock nature and resale value of the car in a negative way... easily reversed.
Any other illumination mods recommended (with good taste in mind that is)?
Received 1,975 Likes
I love mine, the Red Ringed Leaper lights. They are fairly difficult to find the Red Ring ones now, however. The most prevalent location to find them is eBay. Be sure to get the CREE LED, as it is a much better light.
Wow, I tried searching eBay right now and the HTML on the site is messed up.
Now, with a later search.....
2x7w Ghost Shadow Laser Projector Logo Courtesy LED Light Door Step for JAGUAR | eBay
Do all these kits require drilling? I was hoping to find something that is bolt on and uses the existing courtesy light. Not exactly sure where the holes are drilled for this, but will probably not want to modify too much from stock.
Do you have a pic of the actual installation location?
There are units that clip into place where the original red/white light is located, but those cast an elliptical image and it is quite distorted.
Once the lights are installed you would never want to remove them anyway, so 'keep it stock' is nothing you would ever worry about.
If for some crazy reason you DON'T like them, remove them and put a small piece of tape over the hole. Or don't, it won't make much difference.
https://www.jaguarforums.com/forum/x...ts-xks-114619/
Read the entire thread for an analysis of the various options available.
FS[SouthEast]: XK XKR X150 control panel C2P17718
jahummer
05-14-2017 08:24 PM
