Doors locked with key inside!
This is NOT supposed to happen. I know previously when I left the key inside and tried to lock the door, it would beep at me and protest. Today, I was working on the car, driver door open, installing the wheel spacers and the key was left inside on the passenger seat. I pushed to door closed after about 15 minutes but, DID NOT attempt to lock it.
Once I was done with my work, I left the car out for about 30 minutes and when I returned the doors, trunk were all locked, yes, key inside. It was my lucky day that it happened at home where I have a spare key, which was needed to open the door. The car should be smart enough not to lock if it senses the key inside.
The same thing happened to me once with one of my other cars, and never happened again. That time I needed to call AAA to get me back into my car.
Any idea why it would lock one day and not others? Afterwards I tried to do the same thing, left the key inside, came back in 30 minutes and the doors were NOT locked. Now I try locking it by pressing on the exterior door handle knob with the key inside it still refuses and beeps. So much for repeatability...
Albert
Albert
One possibility: If the battery in your Smart Key is weak it might not be recognized if left on the passenger seat, which would allow the car to lock. A weak battery can cause intermittent Smart Key operation. It's cheap and easy to replace.
See: https://www.jaguarforums.com/forum/x...y-issue-63544/
Just my
![Icon Twocents](https://www.jaguarforums.com/forum/images/smilies/icon_twocents.gif)
Stuart
axr6 (04-27-2012)
Albert,
Just my![Icon Twocents](https://www.jaguarforums.com/forum/images/smilies/icon_twocents.gif)
Stuart
Just my
Stuart
It still begs the question how did it lock in the first place? I simply pushed the door closed by its sheet metal and did nothing to actually lock it.
Albert
I never lock my cars in my garage and almost always the car remains un-locked for any period of time. Now that you mentioned this, I remember at least once when I came out expecting to open the door and they were locked. I'm sure I did not lock it by purpose.
Looks to me that there is some electronic gremlins crawling around....
Albert
axr6 (04-28-2012)
I did not lock the door. I ran back for a minute quickly to the house and left the key on the console. I came back and the door is locked. That is not supposed to happen. Yes, it usually beeps and won't lock. What do I do? AAA or do I need to get Jaguar in the morning?? Ugh. How much is this going to cost?
^ Yup AAA pops it open in no time
I had/have the same issue that finally forced me to hide an E-Key on the car so I could always get in... Had to use it already once!
See this thread as well
Vince
Vince
Just a word of advice about leaving keys in your car, even parked inside your own garage.
Last month my garage was broken into. The thief loaded up my 2013 Hyundai Sonata 2.0T with lots of items from the garage. The sherriffs dept and myself felt that if the thief would have been able to find a set of keys in the car, we would have opened the double garage door and drove the car out.
Thus, I make sure that when the car is parked IN THE GARAGE....all car doors are LOCKED, and there is no extra set of keys left in the car.
Just something to think about. The thief filled up the back seat, front seat and trunk with high dollar racing equipment, helmets, Alpine Star gloves. He even took off his old shoes, left them behind, and left with a new pair of Alpine Stars racing shoes.
In addition, he took the car cover off the 2013 Sonata, filled it up with items from the garage and carried everything out as if he was Santa Claus.
This is no joke, but a real experience.
Be aware, be careful....LOCK YOUR CAR, even if in your garage.
Muddydog (12-23-2013)
For 5.0 cars (not sure about 4.2):
EMERGENCY KEY BLADE
To extract: Press and hold the release button [triangular, on upper left side of Smart Key] while pulling the key blade from the Jaguar Smart Key body.
To insert: Press and hold the release button button while pushing the key blade into the appropriate slot in the Jaguar Smart Key.
The key blade operates the left-hand door lock, the luggage compartment lock and glove compartment lock.
Locking and unlocking the doors
Remove the left-hand door lock cover as follows:
1. Insert the emergency key blade into the slot on the underside of the cover.
2. Gently lever the key blade upwards.
3. Carefully twist the key blade, to lever the cover off the retaining clips.
Insert the key blade into the exposed lock to operate.
Note: To refit the door lock cover, push it firmly back into place until it clicks into position.
To lock: Ensure all the doors are closed, then turn the key blade towards the front of the vehicle and release. This will lock the doors, but will not arm the alarm.
To unlock: Turn the key blade towards the rear of the vehicle and release. If the security system is disarmed, the doors and luggage compartment will be unlocked. If the security system is armed, only the front left-hand door will unlock. The interior lighting will be turned on at a reduced level for two minutes.
If the vehicle is unlocked using the key blade with the security system armed, the alarm will sound when a door is opened. To deactivate the alarm, press the unlock button on the Jaguar Smart Key or press the engine starter button with the Smart Key inside the vehicle.
If the Jaguar Smart Key is inoperable, the alarm can be deactivated by docking the Smart Key into the starter control unit.
Basically, that procedure is mostly for a dead fob or a dead car (you can use the key to lock the car if it has no power). Once you've opened the car with the mechanical key, you can 'dock' the fob - it then takes its power from the car, wakes up, and you can press Start.
Ha Ha, Yes, the key is inside the car, thus the blade is inside the car. I always lock the car when I leave it, I just ran back to the door for a second. The fob battery may be low, I doubt they are both low and they are both inside, but... ya never know. Best not to ever ever ever shut the door with the key inside. Calling AAA although Jaguar service 'voice of doom' acted like it was going to be extremely difficult for them to open. Cross fingers.
UPDATE: AAA guy slipped the tool through side of window (convertible) and since key was on seat in plain view he was able to flip it over and push the unlock key! haha
Correct - and, of course, you can't open the car with the emergency key if the fob (with the key inside it) is locked in the car ;-) Basically, that procedure is mostly for a dead fob or a dead car (you can use the key to lock the car if it has no power). Once you've opened the car with the mechanical key, you can 'dock' the fob - it then takes its power from the car, wakes up, and you can press Start.
Lately my automatic locks and start/stop button have not been recognizing my key fob either. I thought maybe it was a sign my car battery was getting weaker, but from this thread I'm thinking I need to replace the battery in the key fob first.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
