Dorman Rear Lower Control Arms--Don't Fit!
Hey everyone just wanted to give a quick heads up that if your looking to replace the rear lower control arms don't use the Dorman brand as the bushing they use for the part that connects to the wheel hub is 5mm too large and thus won't fit. However when I ordered them from Rockauto they didn't indicate this and said the control arms would fit so ended up having to return them and get ones from Mevotech. This is for my 2007 Jaguar XKR.
Btp155 (06-22-2021)
When I owned an X100 I had something similar happen. I ordered some aftermarket bushings than needed to be pressed into the A arms. Or maybe it was a different suspension piece, it's been a while. In any case. They were slightly too big. I ended up ruining a ten ton press trying to press them in. I actually put the bushings in the freezer and the arms in the oven in an attempt to get them in. It didn't work.
Yes I mentioned that in Post #25 here:
https://www.jaguarforums.com/forum/x...-233405/page2/
Im surprised they are still selling them for the XKR knowing that people have returned them.
https://www.fcpeuro.com/products/jag...order-c2p16879
https://www.fcpeuro.com/products/jag...order-c2p16878
never buy anything but these arms. they are the real deal
i brought uro control arms lower an rearward made my problem worst! I used mevotech for the rear of car upper an lower an links so far so good! I mevotech dont make a lower control arm for the front so im trying a brand called Genuine very expensive but not as much as the oem part will update
FreeWifi
26
01-20-2023 04:17 AM
mikewv100
02-19-2013 08:17 AM
