Down on power? Dyno attached
Hello all, so took the 4.2 XKR down to my local dyno today and look to be down on power and massively on torque.. I've had the reduced s/c pulley, exhaust and quaife diff added - supposedly the car also has a nap but I'm now very dubious. Any idea what it could be and how I can get more torque/hp? Thanks
ExKayRick (12-20-2020)
The following 3 users liked this post by Cee Jay:
Thanks, can you think of anything to add some more power alongside the tune? I thought stock torque was around 560ft
You could also use an X-pipe and less restrictive, high-flow catalytic converters but would need a tune. Get a custom tune once, after you've done all the mechanical mods.
guy (12-19-2020)
Received 1,179 Likes
And let’s not forget there is a difference between theoretical yield vs actual yield. I’ve not ever considered it but I know a few that went down the path of blueprinting the engine. Anyone here? That exercise was horribly expensive and only exposed mediocre gains.
Despite @Cee Jay ’s comments ;-), I prefer the look of my ‘07... now imagine it with the 5.0 SC... hmmm.
The following 2 users liked this post by guy:
Mikehill596 (12-19-2020),
Stuart S (12-19-2020)
Now, doing a GOOD engine build is getting all those numbers as close as possible To Each Other and in the either TIGHT or LOOSE side of things is where the POWER is. That's not blueprinting. That's doing a Good Build.
The following 7 users liked this post by Cee Jay:
Blues1 (12-21-2020),
guy (12-21-2020),
ralphwg (12-19-2020),
Sean W (12-22-2020),
and 2 others liked this post.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
MarkyUK (12-21-2020)
Have been told that a decent tune will see a minimum of 50bhp increase over stock and in the map they.can tweak max gains for all my mods.
Will be getting it done when temps come back up, but even as it is straight line me stamping on the loud pedal up to 100mph will make the back end twitch out momentarily before the e-diff reigns things back in
Mikehill596 (12-21-2020)
Agree here, Iherve a 7.5% reduced pulley, no backbox and K&N's fitted, when dyno'd it had lost 17 horses.
True Mike but then you are comparing a (what I beleive is) an open diff on a 4.2 with that of the quaife. It will be a night and day difference.
My (albeit limited) knowledge of e-diffs is that whilst you will still see an advantage with rhe quaife in certain driving conditions it won't be as pronounced.
Only someone that's an replaced an e-diff running XKR with a quaife can really comment.
Also a comparison of your results with your quaife on a drag run compared to a standard 4.2 R will be the real proof
__________________
Will have to politely disagree . I'm still running stock open differential and street tires and have the fastest 0 to 60 times on 4.2lit cars , I'm even beating stock 5.0 cars including 5.0 XKR-S on 0-60 . Check out the screen shot and my time on the bottom, 4.05 or 3.8 with 1 ft rollout vs 4.26 for 5.0 XKRs. So I suspect lsd Will only make a difference If there are substantial traction loss, And I'm sure lsd will make launches a lot more consistent but not faster. Key for running fast with open differential is sticky tires.
Make.sense now?
Mikehill596 (12-22-2020)
That one makes sense to me. But I would argue the diff is good for more than just the straights..
Yea and I get that . I'm sure LSD would improve drivability drastically during lower traction events such as turns, wet road or worn out tires. My point was it won't make you any faster unless you are traction limited on your take off, which I'm still not even with more power. That being said I would love to get LSD unit at one point to experience the difference, wish they were a bit cheaper for experiments sake.
__________________
as I have been saying it's not going to make any difference if I have LSD or open differential , If we would be comparing straight line acceleration numbers
__________________
I don’t have drag strip slips to back it up but when I went from the stock diff to the Quaife, the difference in launch traction was night and day, from not being able to get traction in 1st to almost no loss of traction was quite noticeable and afterwards changing to Sport Cup 2 tires warm and sticky no issues whatsoever.
u102768 (12-23-2020)
