Drag strip time again, surprising results
Went to Barona drag 1/8mi strip last night , was a cool night temperatures as low as 60 degrees
Car was pulling like a beast and had great traction
Most runs were under 8.3 , best was 8.25 at 88mph , best trap was 89mph
For comparison last year, same track with only a pulley mod, was running best of 8.5 at 84mph with 60ft of 1.9
Now compared to last year the temperature is around 10degrees cooler. I have added 2 gallons of race fuel to 7 gallons of 91. I also have done port and polish of a throttle body, opened up stock Intake more and am running an experimental tune from a friend of mine.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
Steve I was at 13.15 on 1/4mi with 107 trap In vegas few month back when I was only pushing 85mph 1/8 trap and with density altitude of 2800 corrected this is around 12.9 and 109mph trap
So thinking 4mph higher trap in 1/8 should equate to 12.5- 12.7 territory around 111-113mph optimistic but that trap speed increase is no joke. I did a port and polish myself. Opening up the intake consists of cutting out plastic grilles in front of the air filter, cutting out extra openings on the bottom of the intake boxes, replacing corrugated rubber connector with straight through silicone pieces. Tested before and after intake restriction with a manometer , results were initial restriction of 21inches per Intake side down to 17 inches , so around 8 inches total restriction reduction or .3 of 1 psi.
__________________
It's interesting that there was so much restriction between the Y and the filters and simple silicone couplings took care of some of it. I had considered opening the air filter boxes up to the side grills and add a balance tube to try and avoid the MAF bias difference CEL. I'd also considered doing a carbon fiber or aluminum intake tubing in true diameters vs crushed how the OEM stuff is. Just wasn't sure if the juice was worth the squeeze.
I found the link to my post on this https://www.jaguarforums.com/forum/x...rboxes-165613/
__________________
What style manometer did you use and how was it hooked up? I have a 0-10" magnehelic that I was going to tinker with but reference it to the Y above the throttle body so I could see inches of water column restriction (loss) out to the filters and snorkels. I also have a Miljoco absolute pressure gauge that reads 10" of mercury when open to atmosphere.
Just fyi I have tried hooking up a slightly larger diameter 3" dryer hose on both sides and didn't see any improvement, so thinking the bottle neck is in the snorkel, maf, airboxes area.
__________________
Makes sense. Sounds like your's is an absolute manometer or it just references the input vs. the cabin pressure. It's probably just academic where it references. I wanted to see vs. the inlet to the throttle body since that 'should' isolate pressure differences to only the plumbing itself.
The same setup could be used to determine after cooler efficiency. On mine when I eventually get there I plan on cooking the oil and crud out and installing a catch can for the PCV circuit. That made a huge difference in my '93 Mustang with keeping the charge paths flowing well and clean.
I don't like how small and convoluted the snorkels are either. I can understand some relative high pressure air behind the grill at higher speeds compensating for the small tubing but the engine is definitely sucking through a straw at low speeds.
Some time I need to pull the nose back off to replace my dysfunctional horns and plan on modding the air boxes then. Probably open the fronts and foam seal them to the nose. I'll add a balance hose behind the grill and maybe a spring loaded flap to avoid water ingestion. I'd love to go generic cone filters down the line as well.
Fun times.
Fun times.
Fun times.
Fun times.
I think what would be really nice, is to have a one way flap that would open inwards and open up the second path of air when there is vacuum or demand for it due to snorkel restrictions, but flaps would stay shut if there is positive pressure coming in from the snorkel.
What do you mean by a balance hose behind the grill?
__________________
From reading, if the MAF signals vary too much side to side it'll throw a CEL. Adding a balance tube (say 2" diameter reinforced hose) between the boxes should keep the relative pressures the same side to side. I'd expect when passing a semi or something similar that the pressure off the front could 'supercharge' that sides air box and trip the MAF, especially if it was high enough on one leg to reduce the flow on the opposite side.
A couple years ago I ran through a death puddle after a heavy T storm. It was a length of interstate during construction that had the middle lane ground off and higher pavement on each side. At the bottom of a dip it was 3-4" deep and 50 yards long. I hit it doing 65 mph and swore I was going to die. The car slowed to 30 mph and pushed a huge wave of water ahead of it. That was with my '93 Mustang and it sits a lot higher vs. the XKR.
Just some thoughts.
Just some thoughts.
