drive cycle 2007 xk
Which part of the cycle doesn't complete??? I'd guess EVAP.
95% of EVAP fails are due to a loose or faulty filler cap on the gas tank. Also, the cycle works best with between 1/4-3/4 full tank.
Regardless, you need to know what fails, there are many possibilities and whoever says it's NOT READY must have that information.
Sean W (08-19-2016)
Usually the EVAP test is the last to complete after a code clear. As CeeJay stated, the tank should be between 1/4 and 3/4 full. On this car, after 3 hours or more of not driving (engine off), drive for at least 10 minutes. Park the car (engine off) and wait at least 3 hours. Then drive for at least 10 minutes again. Park the car and wait at least 3 hours again and then drive at least 10 minutes again. Park the car for at least 30 minutes.
At this point the EVAP test should be completed.
Sean W (08-19-2016)
Steve? You'd know more than I....
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
