Driver & Passenger back rest not moving forward
Hello All,
Have a 2010 XKR where the back rest switch on both driver & passenger seats does not move forward. both switches work taking the back rest on both seats back. All other switches for both seats work fine.
Any pointers/help greatly appreciated
many thanks
many thanks
The following 2 users liked this post by No Quarter:
Jaaaaag!!!!! (03-27-2023),
sony2000 (03-19-2024)
I believe some of the Autel products with their JLR package supports seat calibration plus other common procedures and is much more straightforward to use as well as being reasonably inexpensive. Research the Autel 200 on this forum and check their web site for more info.
VroomForTwo (03-27-2023)
The following 2 users liked this post by Joe7Bros:
Jaaaaag!!!!! (03-28-2023),
Was just about to ask for input. If the Foxwell can recalibrate the seat modules, then it's something the iCarsoft can't do, and it looks to be $40 cheaper or so.
Thinking about picking one up--curious about opinions from other forum members.
I haven't played with the iCarsoft that much, since I purchased it solely to fix the seat issue; apologies I don't have more to offer by way of a review.
I remember a similar scenario happening to my passenger seat when it was at an upholstery shop getting the headliner replaced. The shop owner ended up bringing the car to a friends shop that worked on exotic cars and had it reprogrammed. I wonder if these things happen when the battery runs down, which probably was the case with the headliner installation.
Will definitely check out the Foxwell. Is it worth buying the latest version or will the NT530 with JLR software do the trick ? Just thinking of it as a long term investment ?
Just out of curiosity i contacted local jag dealer, explained issue & here is their reply:
"Good afternoon,
Thank you for your query.
I have attempted to contact you in regards to this, to discuss next steps. We would intially need to perform a diagnostic to confirm what the issue with the vehicle is.
The cost of this is £216, from this we will then be able to confirm a price to perform the repair."
the definition of Highway Robbery ☹️
The following 3 users liked this post by Dymaxxion:
thanks
NT530 recvd. At work at the moment but will try the seat recalibration when I get home. I had a quick look at the NT530 manual online & once the car is identified would i need to go to control modules & locate the seat option & then select special functions in order to recalibrate ?
thanks
thanks
Jaaaaag!!!!! (03-29-2023)
