Driver side window problem
The first thing I'd suggest is doing the Window Reset as outlined in the Owner manual.
Hold the UP button until the window is fully up, then release the button. Immediately hold the UP button again for two seconds and then release. Do the same thing for DOWN. Hold Down button until window is fully down, then release the button. Immediately hold the Down button again for two seconds and release.
Upon the two-second holds, you should be able to hear a very soft 'click' at about the two second mark.
If all that fails, I would disconnect/reconnect my battery and do all that happy stuff again.
Good luck to ya.
Good luck to ya.
ralphwg (08-30-2015)
Thanks! It started working on it own before I saw this.
Good luck to ya.
Good luck to ya.
