Driver's seat module problem?
Even though I never disabled the dip feature, I do not use the passenger mirror for reverse parking. About a week ago I noticed the mirror was pointed at the sky, even though I have a memory position set for normal driving. I set the mirror to my favorite position and continued on.
Today I parked the car at my destination, took care of my business and returned to the car finding the driver's seat switch pack non functional and with no power for the backlight. All other electrics worked fine including mirrors, windows and locks. I disassembled the door thinking perhaps the connector had come lose to the switch pack. That wasn't it. I pulled fuse #9 and it was fine. I also pulled fuse #18 and it was fine but when I replaced it, the seat started working again!
Now the reverse mirror dip went "out of sync" again and a while later I received the message to reset the park brake. I now reset the park brake, disabled the dip feature and set new memory presets.
Anybody have any insight regarding these glitches? Are they all related? Or sign a bigger problem?
Battery time ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I had the very same issue with mine. The first time it happened I pulled out the meter and began tracing wires/fuses etc. I took a break to answer the phone and when I came back, it was working again.
The second time, I just disconnected the battery for a few minutes and voila - back in business.
After that (and a few other electrical oddities), I installed an Odyssey AGM battery and I haven't had any electrical issues since.
jahummer (06-02-2014)
It may not be the issue but, it's certainly the place to start with these cars. There's a whole thread of electrical gremlins caused by a drop in battery voltage somewhere in this forum.
Still sounds like a possibly a low charge in the battery or possibly a defective new battery . Does the car ever sit undriven more than a week at a time? Do you take mostly very short trips?
Check the voltage with the engine off with a multimeter after the car has sat overnight. If you are under 12.3 volts or so all is not well.
jahummer (06-03-2014)
I have been meaning to get a tender for the battery as I did for my Waverunner but have not gotten around to it.
If the car has been off for at least 8 hours chances are the battery is OK (though this type of test is not 100% definitive, since, for example, a battery can still rarely have an intermittent mechanical fault in a cell).
jahummer (06-05-2014)
99xk8guy
06-05-2023 06:28 AM
