Drooping sun visor 07 xkr
DGorvetzian (01-19-2013)
->RTMEYERS1
Thanks very much for your post. My new (to me) 2007 XK has the exact same problem, so I pulled the visors (yes, there is one torx screw that holds the visor in place; gently pry the cover off and you'll get access to the screw) and popped the mirrors out.
It appears that the pole that goes in the visor fits in to a sleeve with a cam, and the body of the visor is made up of clamshell plastic that clamps around the cam. In my case, and I'm guessing in yours, the clamshell's tabs that hold the two halves together have broken, allow the clamshell to come apart a bit, thus allowing the cam to rotate somewhat before it locks and the pole then swivels within the sleeve.
As I look in to the visor with the mirror removed, it appears I have two options:
1) spread Gorilla Glue along the edge of the clamshell and hope that it holds the clamshell together; or
2) pry the clamshell open a bit, inject Gorilla Glue inside the clamshell and let it lock the sides of the clamshell together, along with the cam that's attached to the sleeve.
I think option #2 is the better option, but I'm not sure how long the sleeve is (I can't see inside), and I'm a little afraid of the Gorilla Glue actually gluing the pole to the sleeve such that it won't rotate any more.
Can you provide more specifics on how you used the Gorilla Glue to fix yours, whether or not you injected the glue inside the clamshell, and whether your fix is now still working 5 months later? (The last question also begs the question of whether or not you use the visors regularly, or if you were just concerned about holding them up tight against the headliner.)
Thanks,
Doug
Thanks,
Doug
LoudHogRider (01-13-2016)
Yeah, this is my 7th Jag, and the first 5 were all between 13 and 33 years old when I sold them. This car is just 5 years old, and I'm really surprised at the number of small plastic bits that are already broken on this car. Both visor clamshells; glove box latch mechanism; connection pin for glove box damper. It does indeed make me a bit concerned about my ability to keep this car past its 10th or 15th birthday. Aside from the expense of keeping everything working properly, I'm not very confident that Jag will continue to make and stock the little bits that break over time.
I recall trying to get a replacement plastic retaining bezel for the convertible top switch for my 7 year old XJS, and Jag simply stopped making them. Period. Out of luck.
I hate Mercedes, but one thing I must give them credit for is that there's almost nothing you can't buy for a Mercedes -- ANY Mercedes. The part might cost an arm and a leg, but if you want a brake light lens for a 1956 MBZ, you can most certainly get one. It's not even a question.
Alan,
Not sure; mine were busted when I bought the car, so I'm not sure what the pre-failure scenario was. My guess, however, is that you're just hearing some stickiness between the post and the sleeve in which the post spins. Once the clamshell breaks (and thus allows the cam to rotate a few degrees within the clamshell), I think you'll see it because the visors won't snap hard against the headliner. They'll droop by the same amount that the cam is rotating within the visor.
I guess it's possible that the clamshell could be partially separating, allowing the cam to rotate just a tiny bit -- not enough that you would notice the visor drooping. As the clamshell separates further, it will provide more rotation room for the internal cam, and then (I'm guessing here) the visor will droop lower and lower.
/Doug
/Doug
amcdonal86 (01-20-2013)
Received 9,007 Likes
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/30581-drooping-sun-visor-07-xkr-car01.jpg?dateline=1358531784)
Ok so you guys have the newer model, but surely this helps some?
Please see below....
Visor Mirror Repair (Video) FAQ - Jaguar Forums - Jaguar Enthusiasts Forum
I'm sorry. Just saw this. My wife uses all the time and it is still holding very strong. A little gorilla glue goes a long way. It does expand as it drys so you need to hold the visor together firmly. I rotated the mount carefully a few times while drying and was careful with the glue and it did not effect the rotation……. Thanks, Rick
DGorvetzian (02-05-2013)
Alan,
/Doug
/Doug
vacolorito
09-25-2015 09:29 AM
