The Duckbill, updated status on this issue
Hi all. My duckbill issue has not gone away, I’ve tried many things suggested in forums and some own inventions with part disassembly and coathanger wire. The problem is still there. So I’ll have to get it fixed this winter and I plan to do that myself.
The big question is, from above or from below? Should I take the dash apart or should I lower the transmission? I ask for updated information and please, don’t get me wrong, but please only answer if you have done this work yourself/have 1st hand knowledge. I’m not asking for hear-say, and no “my friendly garage told me”.
So, after having read the forum about this, and found some inconsistent views, here’s what I’d like to know from those that have done it themselves:
From above:
Any particular problems taking all this apart? I assume it’s in the service manual? Does the A/C has to be taken apart so it needs refill, or can it be pushed to one side still filled while the duckbill is replaced? Mine is a LHD car, any issue with that? Hours used?
From below:
Is it “just” to remove crossmember and lower rear of transmission? How many inches to get room? Will exhausts attached to the engine fight this, risk of something cracking? Any other things to know? I know it has to be cold to be able to work on. Will this enable one to replace the duckbill with the newer version, or only give room to cut etc in the current duckbill? Hours used?
Anybody reading this that have done both, which do you prefer?
From above:
From below:
Received 2,048 Likes
I've done about ten of them, all from above, removing the dash assembly. Dash comes out, Heater/cooler box can be moved to the side enough to access the drain.
Yes to disconnecting AC and heater hoses, blow some air in the hoses before you remove the dash and you will have less coolant on the floor.
Tried several times from below without success.
George05 (09-06-2019)
Just to make sure, you say the heater/cooler can be pushed to one side, but still one would have to disconnect both heater and AC lines, and then later reconnect and fill again?
Tried from below, have you tried to lower geargox or "just" tried to work around it?
Wanting more info on duckbill
The duckbill issue seems to have lots of stories. I agree with this posting that it is hard to figure out what exactly is the best approach. On the XKR2008, there is very little room to get anything down by the firewall. I have an endoscope, but cannot find the duckbill. I continue to wonder if lots of the postings get confused with year of car and XK vs XKR's
Some photos, drawings and really good details on the XKR would be helpful. I am enclosing a photo with a ruler laid out. If someone can suggest where the opening is that could provide access, using the numbers on the ruler, that would be helpful. Also, exactly how far down and how far inward, dimensional, would be helpful. I have not seen much chat about removing the turbo cross over pipe, Is that because that is not very effective or is it just really difficult to execute.
The dealer says the trans and exhaust both have to be moved to get a knife at the duckbull. Is that fact or just the easier, more expensive process. Some seem to say that dropping the trans is all that is required.
The forum is very helpful and I am hoping not to write the big check to the dealer, now that it is fall/winter, I have lots of time to address this issue.
To me, it is insane that Jaguar has not developed a special tool that could allow the mechanics to find their way to the duckbill and slice it off, it must be something that will eventually come around to all cars, truly a design defect.
Howell, it's all solved, 30 minute procedure. Duckbill is in the middle at "740" marking. But read this:
https://www.jaguarforums.com/forum/x...-doing-222930/
Not saying it can’t happen to you, but less likely.
Further back-reading said a new design was installed around VIN B34499, and that some early 2010s might still have it...
If it helps. Well, it helped me understand the issue. Attached is picture with the AC unit removed. The duckbill drain is circled in yellow, and the hole it sticks through circled in red. Looking at it, it seems obvious that in a warm humid environment where it rarely dries out, it would get gunked up and clogged with moss. I’m surprised that rather than having to remove the dash and the AC unit, or dropping the tranny, Jag would have developed a tool to get to it. I could imagine something like an extended orthoscopic type tool, with a moveable end that could be used to enter the orfice and clear it out. ‘cause some of u# have big catcher mit paws that won’t fit there.
McJag222 (12-17-2023)
steve_k_xk (12-18-2023)
