Dumb Coolant Reservoir question
'09 XK convertible NA:
So I'm replacing the coolant reservoir because I have the typical leak where the bottom hose comes in. Get everything taken apart - the part that takes the most time is taking all the coolant out with a baster.
Figured out I needed to loosen the strut support to slide the old tank off. Feeling pretty smug at this point.
Then as I'm unwrapping the new tank from the bubble wrap it came in, I lose control and drop it. Right on the fitting that the bottom hose attaches to, and I broke the darned thing. Dumbest move ever.
That wasn't my question - I just told that story to make you feel better about yourself at my expense. Here's my question - the NEW coolant reservoir has a sensor in the bottom - the OLD one that I took off hte car does not - it has the fitting for the sensor, but nothing is in it. I don't think the NA had the temp sensor here - it's somewhere in a coolant line. Is that correct?
Thank you.
Thank you.
The sensor in the reservoir is not a temperature sensor, but rather a fluid level sensor to let you know if the reservoir fluid level is dropping too low. The temperature sensor is located in the thermostat housing at the front of the engine.
Hence you can remove the fluid level sensor from the new reservoir before installation.
Thank you.
Thank you.
You are correct and the tank was updated for the 5.0 cars. It is the same tank as it will fit all models . They stopped making the older style tank.
Rickkk
08-13-2019 08:59 PM
