E diff warning light
With DSC on, you get Electronic Traction Control, where the ABS module can brake the spinning wheel(s) and/or command the ECM to reduce torque. It also provides yaw control, using individual-wheel braking and torque reduction to avoid oversteer/understeer.
With TracDSC, the thresholds where the system cuts in are increased, i.e. more wheelspin is allowed, and greater yaw angles. But it still cuts in to try & protect your hindquarters, which is nice when you encounter some other car's vital fluids dumped in the middle of a corner.
With DSC off, there's no traction or yaw control - your right foot is in charge. Things can get lairy...
I believe all the other stability features are always active, like Corner Brake Control (stops inside wheel lockup when you brake while cornering), Electronic Brake Force Distribution (stops the rears locking due to weight transfer during braking) and Engine Drag-Torque Control (stops the rears locking on downshift/throttle-off)
andys-GR (01-21-2015)
Thanks Ngarara.
Further update E-Diff System Fault warning back on
car goes back to the dealer Monday.
Strange thing I drove her last night and the suspension felt stiff like Dynamic mode was engaged, and when switching between I could not feel the difference, but code did not turn up until this morning.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I was gonna say when you get an MIL trigger it at times could be a false read of a sensor so I would erase the code. If you get a 2nd hit of the same code that tells me there is a problem with the sensor or control system or the component . Cleaning the connector apparently was a temporary fix but being it returned it is a bigger problem. Just out of curiosity do you know if the dealer interrogated the voltages at the connector prior to just cleaning and greasing the connector. This I would thing is the diagnosis method to rule out any module signal. Good luck and keep us posted
I don't know if they checked voltages. I'm thinking there is a control fault because the suspension stiffened last night before the code and is back to normal now with the code gone so there is deeper going on I think. But is there checking with Jaguar theres not much more for me to do just yet.
#28
#30
Andy I hope it is the fix but call me a little skeptical. I don't know if you asked to see the problem connector but my habit it to request all bad parts to be available for me to see or take with me. Think about what could go wrong with a connector. Either it needs to be crushed/broken or corroded from water or oxidation. In either case you should be able to see the problem. Next is when they fixed the connector did they replace it or did they cut off the old connector and splice in a new one. How was the repair done would be my question. We'll have to see how this goes . Fortunately I have a lift and if I couldn't see the repair at the dealer it would be the 1st thing I do when I got the car home. Good luck.
#31
#32
#33
andy I fear you will be in for a long wait here. I suspect they will need to pull apart the differential to find the problem. I don't know the details on how the e-dif works but I suspect it has some type of electric clutch or solenoid that engages to make it function. So if it isn't a relay function problem in the circuit then it's in the differential itself. It's not a problem with the ring and pinion or the input or output shafts because the car still drives OK ( I assume). So it has to be with the method it hooks up the other drive circuit/system. Tell them you want to see the parts they remove/fix. You may also want to suggest to them you think they should replace the differential as a unit and see what their opinion is of doing that. Good luck and please keep us posted especially as to what the final problem is.
andys-GR (02-04-2015)
#34
#35
OK I just found out how this system works. Here is the description of the F-Type but I suspect it is the same for the XKR.
Pretty cool but complex also. Kind of make you wonder how long the clutches will last.
2014 Jaguar F-Type Differentials, Electronic Aids: 30 Days Of F-Type
#37
She's back to the dealer today E diff warning light on again.
They are also replacing a piece of cracked interior trim, replacing the torn lower stabilizer bar ball joints. In addition they are lubing the drivers door again since I had to spray it with deicer last week to get it to shut smh.
Still waiting on the promised buy back figure.
#39
#40
