Easiest place in the back to get a signal for a subwoofer?
I changed the tweeters and it helped, but i want put in a subwoofer. Easy to get breaking power from the back, but it seems I have tear apart half the car to find at least a loudspeaker signal. That will do very well. i took away the rear seat, lots of cables there...impossible to say which on carries the audio signal. Any suggestions? I do not want to take the signal from the front side of the car.
Asked and answered already I think. I don't believe thee is one in the rear.
https://www.jaguarforums.com/forum/x...al-sub-192833/
I added 2 Kenwood KSC-SW11 (on behind the driver's seat and another behind the passenger seat), spliced off of the rear speakers - sounds so much better. I also changed out the front speakers to Focals and they sound so much clearer and crisp, as well as the sub in the footwell (fills out the sound a little more). Changing the rear speakers made no difference at all and I went back to stock.
I used the rear speakers. Yes, you have to remove quite a few pieces, and IIRC, the trim at the tread plate (snaps up and I believe its also a 25 torx screw), then the panel that the rear speaker sits in. A bit of a pain, but not terrible, and the results of getting the signal for the subs is well worth it. As for power to the subs, there is a switch power source in the trunk (there are a few threads on it, and at the moment I don't recall which treads particularly).
orangeblossom
03-13-2017 10:59 PM
jagosaurus
05-23-2013 12:48 PM
