Easy way to calculate HP? My MAF G/S is 382
So after a little bit of digging it turns out that G/S MAF measurement gives a relatively good HP Estimate
This is what I found on the net
N/A and Turbo Engine HP= MAF (g/s) * 1.25
Supercharged Engine HP=MAF (g/s) *1.1
N/A and Turbo Dynojet WHP manual= MAF (g/s) * 1.1
Supercharged Dynojet WHP manual =MAF (g/s) *0.95
Using the 1.1 ratio I get 420 hp flywheel hp or 362 at the wheels on Dynojet
wow just as my car stock hp rating
Please share your results!
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
It is indeed a good indication, I have also used this myself in the past to check tuning progress. At least you can see if you have made progress when it comes to airflow modifications, however it doesn't take any inefficiencies into consideration.
You need to have a good odbii meter, preferably the IDS as it takes more measurements per second. Without the IDS, make sure you only select the MAF sensor for reading, that gives about 6 measurements per second, and next the higher the gear to more precise it becomes (ie 3rd was always ideal, but fast).
Just an Update
went to 397 G/S on a entrance ramp , translates into 436 flywheel hp
Anyone else have numbers to compare?
__________________
UPDATE:
so I tested the maf into hp calculator on my other car, 2000 Mercedes e55 AMG (stock hp rating 349hp) my car has cats removed and intake modifications
got 284 G/S max which translates into 355hp which is very darn close to what it should be
Thumbs up !!
Thumbs up !!
__________________
jahummer (02-08-2017)
Alex are you taking the measurements in 3rd as Avos suggested if not , which gear are your measurements taken at .
It doesn't seem to make a difference 2nd vs 3rd gear
I put car in manual mode switch into 2nd and floor at at around 2800rpm all the way red line without switching gears, car will do it for you so dont worry.
__________________
It actually does, at least when you want a good reading. Its simple, in 1 second you spawn a big rpm range in 2nd compared to 3rd. Only the IDS is relatively fast enough in measurements per second to use 2nd gear, but even then.
Redline in 3rd for me is 180kmh / 110mph, I'll be thrown in jail if I get caught doing that on the street here...
If you only have Torque available, then set up the screen to only record one measurement, the MAF rate. The more measurements you have going the slower the refresh rate.
I was using dash command and recording gear, speed and rpm but could set it to just MAF.
Attached is an old example (probably done in Germany), when my car was still stockish in 3rd gear (4.0 gearbox, so 4,31 final gear ratio). You see that 5000 to 6000 rpm took about 5.2 seconds. Have no idea what odbii reader I used then, but you can see roughly 6 recordings per second.
A 2nd gear for a 4.2 car with a ZF6HP gearbox, has a final gear ratio of about 7,75 and am not sure what speed range that will give you, but I would guess from 5000 to 6000 rpm would be done in maybe 2 seconds or so? That means much less granularity pending on the device you use to record.
So bottom line is that of course you can use only 2nd gear, certainly if it’s just a fun reading, but if you want to use it to see if you make any improvements in airflow, you need more granular readings if you see what I mean.
So just do a recording, and as Cambo mentioned only select the MAF to get the best readings in a low gear.
jahummer (02-11-2017)
The exact same numbers shown for 1.6 seconds ? Seems like you've missed a lot of data there...
It was trying to capture 14 different metrics so I might have been swamping it. 374 actually spans from 01:47.6 to 01:49.8 in the original spreadsheet and the numbers either side are 194 and 27 so it is no where near as granular as the one avos posted.
I will try again and see if I can get some more meaningful figures.
Maybe not, it depends on the tune.
There are a number of limiters in the PanPag PCM which could negate the peak HP effects of a pulley, if they aren't addressed then yeah, peak MAF numbers may not be higher than stock.
For example there is one limiter "Maximum load" which is an upper limit of the volume of air coming in to the engine, if this value is reached the PCM starts to close the throttle, that value needs to be raised in the tune or you will hit the ceiling, so to speak...
Im using torque pro app with a cheap Amazone bluetooth adapter. In torque app make sure to select highest refresh rate, I think its 12times/second.
__________________
