Emergency key will not open trunk…
Greetings, good citizens of Jag Forum. So, I go down to go out on a proverbial joy ride, press the key fob, and nothing. I used the emergency key to get inside and nothing, no lights or warnings, everything is absolutely dead. In the two years that I had this car, it has been solid mechanically. Always starts, trying to stay ahead of the maintenance curve I installed a new battery 9 months ago. I checked the battery fob with a tester and got 3.1 volts.
I go to open the trunk and I can barely get the key to go halfway to one o’clock clockwise. Straight up at 12 o’clock going counterclockwise, no movement. My understanding is I should turn the key clockwise while pressing the truck release button. Please let me know if there is more to that or any tricks or hints that you may have.
Thank you.
2007 XK – 33.4k
Thank you.
2007 XK – 33.4k
7500ftJagGuy (06-25-2023)
The following 2 users liked this post by JackJohn:
7500ftJagGuy (06-25-2023),
guy (06-26-2023)
The following 3 users liked this post by tberg:
Emergency key will not open trunk… Resolved
Success! I slid the cover off of the positive post then hooked up my jumper cables, waited 5 minutes and the car started right up. I did get the "cruise control is not working" message but I have fixed that in the past. I just need to find the post. She is now close an outlet, connected to her Ctek charger and hopefully, we will be good to go.
As always many thanks for the help and insight.
tberg (06-25-2023)
dniqueo7
10-23-2022 03:41 PM
