Emergency steering rack issue
OK, ran over something last Sunday and it cut a two inch gash in the right rear tire. Called a tow truck to take it to the nearest open facility (Ft Pierce Fl). Tow guy had trouble getting the car on the lift. Anyway, nearest open place was Pep Boys. They took the flat off, determined it couldn't be repaired and put on the mini-spare so I drove home, noticing my steering wheel was now facing 11: o;clock instead of 12. I ordered a new tire from Tire Rack and had it delivered to a facility in Port St. Lucie, Fl. It arrived on 07/03. I drove down and had them install it. Today I stopped at the Jag dealership in Ft Pierce to have them check the alignment, thinking that was the problem. An hour later the service advisor says they found the problem. "Did you gave the car towed?" he asked. I said yes and he had the mechanic point out that the tow truck guy hooked up to the steering rack instead of the tow hookup. He bent the steering rack. Cost of new rack and labor? $3700. I called the tow truck company and they are denying it was their fault. Turns out it
s a small indy tow operation, with a pretty bad reputation. Advice needed...eat the cost and move on, take the tow company to small claims court or, looking for a plan C.
Received 1,975 Likes
https://www.ebay.com/itm/JAGUAR-XFR-...ally+Aspirated
If it's only the tie rod then they separate the outer from the inner pop the boot and remove the inner once the fluid drain. Assembly is pretty straight forward and it'll need an alignment once done.
Per the tow company, document it and talk to your insurance about the value of doing a claim versus eating the deductible and higher rates. They may go to bat for you.
All retrospect and of no use now, but where were you when it was getting towed? Not that everyone in the world knows about installing a tow hook into the bumper, but I do know that if someone I don't know is messing with MY car I'd be danged sure that they were doing so correctly.
So, this is mostly a word to anyone else out there........ Know how your car should be towed! (and hoisted)
It really does suck that someone in the BUSINESS of towing doesn't know their ****, but evidently even a lunatic moron can get elected president.
Profit margin is way higher and they are less liable if something else is tweaked in the steering linkage and they don't find / fix it the first time. Dealer tend to do sub assembly replacement when possible, not component replacement.
I wouldn't let the dealer touch any suspension components, they'll have you replacing all the bushings and joints before it's all over.
chazaroo (07-07-2018)
Tie rods are around $100 as I'm sure you have seen. Rebuilt racks for these are plentiful and only a few hundred. Installation is pretty straight forward. For half the price the dealer quoted you, you could have a new GT/F-type rack for improved steering response and feel.
I saw them towing a XJ (from a dealership, so not a repo) where they could not figure out the emergency brake release, so they dragged it with tries screeching and the car put up a hell of a fight.
