Engine Air Filter
The bloke who designed the position of this air filter should be made to replace it 10 times in a day. Surely an engine air filter should be in a place where it can be got at in less than 3 hours ! All of this dismantling ( and re-assembly, of course), needs labour time at around £90 an hour in the UK, probably more. Barmy !!
This is a JOKE right??? I'm looking at a 2008 XK with 34K miles and have no way of knowing if the dealer (non-Jaguar high end dealer in Chiacgo) has changed the air filter or is leaving this to the poor smuck that buys it.
This alone makes me wonder what else they didn't design with an owner in mind.
Tom
Speaking of the air filter travesty....does anyone know if the 2010 air filter is the same size as the 2007-2009? Just curious as K & N has a 2010 filter now and was just wondering... I used to have a spare housing around but can't seem to find it so if anyone knows the dimensions of the 2007-2009 Filter I would much appreciate it. BTW there have been 2 or three guys on this list over the years that have done some real interesting things with the intakes and filters. FWIW I would also add that although the filter change appears to be daunting it really isn't that bad and a motivated guy could do it in a few minutes...assuming he has a power driver for the fasteners :-)
No Need to Remove Air Cleaner Box to Change Filter
If you remove the wheel, then you do not have to remove all of the underbody panels or remove the air box. Just remove the 8 Torx 30 bolts from he wheel well liner and pull it back out of the way. Unscrew the 2 Torx 25 screws at the top and bottom of the filter box access door and then pull hard on the door to remove the filter cartridge. Purolator A35817 air filters are available from Advance AUto for about $19 each.
Be advised that the supercharged engine has an air filter box on each side.
Bill
2007 Jaguar XKR Coupe
1997 Jaguar XK8 Coupe
1987 Alfa Romeo Spider Veloce
1969 Jaguar E-type Coupe
Bill
Bill
Bill
This car is for my wife and since it has 35K miles I'll want all fresh fluids/filters before I turn her loose.
Thanks so much.
Tom
And the supervisor that either signed off on it or insisted on it to begin with should be made to do it in 0.3 hours per car, unless SC, then 0.4 hours, 24x7, or suffer 100 lashes for each failure to meet the time. The time for lashing to be deducted from his allowed time for the next vehicle.
They might as well have added the air filter(s) to the sealed for life list.
Wonder what the QuickLubes of the world think of this one.
air filter replacement instruction sheet
I am still trying to figure out the best way to attach PDF and JPEG files.
If this doesn't work, then send me an email to blackriverexp@att.net and I'll forward you a PDF instruction sheet with diagrams that I have made up.
[IMG]c:\workfile\temporary\air filter replacement.jpg[/IMG]
Bill Unger
2007 XKR
1997 XK8
1969 E-type
Bill Unger
2007 XKR
1997 XK8
1969 E-type
